Привет. Заменил проц на роутере. Поставил AR7241 вместо AR7240. Перепутал пины как положено. Роутер заводится, но сеть в компе не идентифицируется.
Что можно сделать?
Что можно сделать?
Спойлер (+/-) (serial)
U-Boot 1.1.4 (Dec 5 2011 - 15:05:27)
AP91 (ar7240) U-boot
DRAM:
sri
#### TAP VALUE 1 = f, 2 = 10
32 MB
id read 0x100000ff
flash size 4194304, sector count = 64
Flash: 4 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ag7240_enet_initialize...
No valid address in Flash. Using fixed address
ag7240_hw_start: MDC check failed
: cfg1 0xf cfg2 0x7014
eth0: 00:03:7f:09:0b:ad
eth0 up
: cfg1 0xf cfg2 0x7214
eth1: 00:03:7f:09:0b:ad
ATHRS26: resetting s26
ATHRS26: s26 reset done
eth1 up
eth0, eth1
Autobooting in 1 seconds
## Booting image at 9f020000 ...
Starting kernel ...
Booting AR7240(Python)...
Linux version 2.6.15--LSDK-7.3.0.300 (zhongjin@rd3linux.tplink) (gcc version 3.4.4) #4 Mon Dec 5 15:08:08 CST 2011
flash_size passed from bootloader = 4
CPU revision is: 00019374
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
User-defined physical RAM map:
Built 1 zonelists
Kernel command line: console=ttyS0,115200 root=31:2 rootfstype=squashfs init=/sbin/init mtdparts=ar7240-nor0:128k(u-boot),1024k(kernel),2816k(rootfs),64k(config),64k( art) mem=32M
Primary instruction cache 64kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
Cache parity protection disabled
PID hash table entries: 256 (order: 8, 4096 bytes)
Using 175.000 MHz high precision timer.
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 30548k/32768k available (1366k kernel code, 2204k reserved, 293k data, 128k init, 0k highmem)
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
NET: Registered protocol family 16
PCI init:ar7240_pcibios_init
Reset button pressed.
Returning IRQ 48
AR7240 GPIOC major 0
squashfs: version 3.3 (2007/10/31) Phillip Lougher
squashfs: LZMA suppport for slax.org by jro
Initializing Cryptographic API
io scheduler noop registered
io scheduler deadline registered
Serial: 8250/16550 driver $Revision: #2 $ 1 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x0 (irq = 19) is a 16550A
RAMDISK driver initialized: 1 RAM disks of 8192K size 1024 blocksize
PPP generic driver version 2.4.2
PPPoX init, max protocols:3
NET: Registered protocol family 24
pppox protocol 0 register. max:3
cmdlinepart partition parsing not available
Searching for RedBoot partition table
5 RedBoot partitions found on MTD device ar7240-nor0
Creating 5 MTD partitions on "ar7240-nor0":
0x00000000-0x00020000 : "boot"
0x00020000-0x00120000 : "kernel"
0x00120000-0x003e0000 : "rootfs"
0x003e0000-0x003f0000 : "config"
0x003f0000-0x00400000 : "art"
->Oops: flash id 0x10215 .
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
ar7240wdt_init: Registering WDT success
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 128k freed
init started: BusyBox v1.01 (2011.08.29-03:02+0000) multi-call binary
Algorithmics/MIPS FPU Emulator v1.5
This board use 2.6.15
ip_tables: (C) 2000-2002 Netfilter core team
ip_conntrack version 2.4 (256 buckets, 5120 max) - 244 bytes per conntrack
ip_conntrack_pptp version 3.1 loaded
insmod: cannot open module `/lib/modules/2.6.15/kernel/flashid.ko': No such file or directory
pppox protocol 1 register. max:3
PPPoL2TP kernel driver, V0.17. fixed many bug. drop rcv pkts and xmit pkts while no buffer, use pass time HZ/4.only drop ip pkt. no printk. xl2tpd 15 retries xmit. 08.20
PPTP driver version 0.8.3
pppox protocol 2 register. max:3
insmod: cannot open module `/lib/modules/2.6.15/kernel/harmony.ko': No such file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/cdc-acm.ko': No such file or directory
Now flash open!
Now flash open!
sys_mode=0 mac:8106c000 ag7240_macs[0]:00000000 ag7240_macs[1]:8106c000
2
sys_mode=0 mac:81c94000 ag7240_macs[0]:81c94000 ag7240_macs[1]:8106c000
1
+++ pvid_bitmap initial
ag7240_hw_setup: MDC check failed
sys_mode 0 PHY4 auto-negotiation enable
Attention: PHY4 Class A setting in debug 5 register which is not described in DS
phy_setup ethUnit:0 phyUnit:4
Port 4, Neg Success
(none) mips #4 Mon Dec 5 15:08:08 CST 2011 (none)
(none) login: ATHRS26: resetting s26
sys_mode 0 PHY0 auto-negotiation enable
Attention: PHY 0 Class A setting in debug 5 register which is not described in DS
sys_mode 0 PHY1 auto-negotiation enable
Attention: PHY 1 Class A setting in debug 5 register which is not described in DS
sys_mode 0 PHY2 auto-negotiation enable
Attention: PHY 2 Class A setting in debug 5 register which is not described in DS
sys_mode 0 PHY3 auto-negotiation enable
Attention: PHY 3 Class A setting in debug 5 register which is not described in DS
++++ athrs26_igmp_setup once
vtable vid: 0x00000002, bitmap 0x00000003
+++ athrs26_igmp_vtable_create failed
---- set vlan table error
phy_setup ethUnit:1 phyUnit:0
phy_setup ethUnit:1 phyUnit:1
phy_setup ethUnit:1 phyUnit:2
phy_setup ethUnit:1 phyUnit:3
Port 0, Neg Success
Port 1, Neg Success
Port 2, Neg Success
Port 3, Neg Success
device eth0 entered promiscuous mode
device eth1 entered promiscuous mode
ath_hal: module license 'Proprietary' taints kernel.
ath_hal: 0.9.17.1 (AR5416, DEBUG, REGOPS_FUNC, WRITE_EEPROM, 11D)
wlan: 0.8.4.2 (Atheros/multi-bss)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_pci: 0.9.4.5 (Atheros/multi-bss)
ath_pci: cannot reserve PCI memory region
wlan_me: Version 0.1
Copyright (c) 2008 Atheros Communications, Inc. All Rights Reserved
wlan: mac acl policy registered
====>>>>Making VAP ath0
====>>>>MakeVap: Wireless driver didn't loaded yet !
====>>>>Making VAP ath1
====>>>>ATH0 MAC: 90:F6:52:5B:C5:84
====>>>>Cloned MAC: 90:F6:52:5B:C5:85
====>>>>MAC MASK: FF:FF:FF:FF:FF:FE
====>>>>Clone Wan Mac for APC RoNow flash open!
uter
ip_nat_pptp version 3.0 loaded
ip_conntrack_rtsp v0.01 loading
ip_nat_rtsp v0.01 loading
+++ GE0 RX DMA ENABLE
DRAM:
sri
32 MB
id read 0x100000ff
Flash: 4 MB
In: serial
Out: serial
Err: serial
eth0 up
eth1 up
eth0, eth1
Starting kernel ...
Built 1 zonelists
Returning IRQ 48
TCP reno registered
TCP bic registered
Now flash open!
Now flash open!
2
1
Port 4, Neg Success
Port 0, Neg Success
Port 1, Neg Success
Port 2, Neg Success
Port 3, Neg Success
uter
