Помогите пожалуйста вернуть к жизни устройство
Зашивал 2611CB3-DV2.0.0 по tftp
Во время прошивки (после 8 пункта) перестала отвечать на ping 192.168.1.1, но сетевая плата показывает 10мбит, не светятся светодиоды LAN,WLAN (Power горит)
Все делал по инструкции для животных приведенной ниже
1. Unplug the device, hold down the reset button, and then plug the power back in.
Notice that the LAN LED is flashing. Release the reset button after 5 seconds.
The device will then reboot into its default configuration (192.168.1.1)
Note: This step is mandatory and will reset the device to its factory
default settings. (All previous settings will be lost.)
2. Change your computer's IP address and subnet mask to the following:
IP Address: 192.168.1.10
Subnet mask: 255.255.255.0
3. Successfully Ping 192.168.1.1
4. Launch the web-browser and connect to the device using its default IP address:
http://192.168.1.1
5. To Login, leave the username and password fields blank. Click on the OK button.
6. Click on "Admin" on the left menu bar, and then click on the "Switch" button to
switch to AP mode.
7. Once the switch has been completed, refresh the page.
8. Extract the firmware folder and then double click on "Do1.bat". Watch the LAN
& WLAN LEDs flash for a few seconds. It will then stay lit.
9. Unplug the device and then plug the power back in. Wait for 10 seconds.
10. Successfully Ping 192.168.1.1
11. Double click on "Do2.bat".
a) If your WLAN Primary firmware was less than 1.0 you will notice both the
LAN & WLAN LEDs flashing. Then the LAN LED will stay lit.
b) If your WLAN Primary firmware was 1.0 or greater, you will notice that only
the LAN LED is flashing. Then the LAN LED will stay lit.
12. Unplug the device, hold down the reset button, and then plug the power back in.
* Note: This step is mandatory and will reset the device to its factory
13. Successfully Ping 192.168.1.1
14. Launch the web-browser and connect to the device using its default IP address:
http://192.168.1.1
15. To Login, leave the username and password fields blank. Click on the OK button.
16. Click on the "System" on the left menu bar, and then verify "Bridge Firmware".
This should display the following:
AP Firmware: 2.0.0
WLAN Primary Firmware: 1.1.1
WLAN Secondary firmware: 1.8.0
WLAN Tertiary firmware: 1.3.8
Firmware Upgrade Complete.
На корпусе наклейка SL-2611CB3 PLUS (DELUXE)/E(F200)
На плате - SL-2611AP3 PLUS-1.00 и желтая наклейка APV1.9.0(A) BCV1.8.0(A)
Вставлена карта SL-2511CD PLUS EXT2(F200)CY
http://192.168.1.1
switch to AP mode.
http://192.168.1.1
AP Firmware: 2.0.0
