Сейчас тружусь над AcorpWR-N(L), девайса 2 штуки оба на Ralink:
RT3050 - 1T1R 4/16Mb
RT3052 - 2T2R 4/32Mb
384МГц CPU MISP Little Endian.
Текуща версия прошивки 1.0.0.2.
Известные проблемы:
<none>
Changes:
1) Fix configs scripts for support bash >=4 and change product name
2) Kernel version up to 2.6.21.7
3) Redesign filesystem. Busybox up to 1.15.3
4) PPPD up to 2.4.5 with more patches as acell-ptpp/l2tp/gigaworld/allow-mppe/etc
5) Add ACELL-PPTP Kernel support
6) Mount ramfs particions in kernel mode
7) BGIDGE: Pause frames shouldn't be passed up by driver anyway
8) Add ESFQ support
9) Initial auto detect memory size (fix me 32bit mode support)
10) Add udpxy
11) Code cleanup
12) Remove ASUS Code
13) Original Ralink gui now work
14) pptp/l2tp/pppoe tun now works
15) Full rc scrips is write in rwfs
16) RT3052F embed switch full work now
17) Rewrite pptp/l2tp/pppoe scripts to support buggy nas (corbina etc)
18) miniupnpd now work too
19) Add rwfs support (fs save | fs restore | fs load)
20) Auto set mss size
21) Masqrade now work correctly
22) IMQ support added
23) Initial shaper scripts (default priomap and esfq for decrase torrents prio)
24) Kernel ip account support added
25) Fix crash on sta list
26) Update userspace daemons and utility
27) Some busybox fixes
28) Auto generate UUID for UPNP service on first upnpd start
29) Check if ppp is up do not change ip from dhcp
30) Regenerate mac if drop to defaults
31) Some services start only then start goahead
32) Replace some code from original Ralink SDK version 3.3
33) Integrate new web gui in current sources tree
34) Static routes get from dhcp server (options 79)
35) busybox update to 1.16.0 version
36) Replace ntpclient to ntpd from new busybox
37) Add multiple default gateway support for load balacing
38) Fix boot on 4/16 devices
39) RootFS on flash work OK
40) Fix resolve server ip for pptp/l2tp
41) Add support others type falsh
42) Job control fix
For support see:
acorp.ru - Acorp Electronics Inc.
ddixlab.ru - Laboratory of built in systems.
News and changes in Russian:
sadnet.ru - Development opensource routers firmware
Bug report please send sfstudio[_at_]mail.ru
Желающие добавить поддержку других девайсов welcome с патчами.
Все обсуждения касательно прошивки ведуться тут http://forum.nag.ru/forum/index.php?showtopic=54015
Прежде чем писать советую прочитать тему целиом.
Известные проблемы:
<none>
Changes:
8) Add ESFQ support
10) Add udpxy
11) Code cleanup
42) Job control fix
For support see:
