Wive-NG-RTNL Ralink RT3050/RT3052 firmware
    Сейчас тружусь над AcorpWR-N(L), девайса 2 штуки оба на Ralink:
    RT3050 - 1T1R 4/16Mb
    RT3052 - 2T2R 4/32Mb
    384МГц CPU MISP Little Endian.
    Текуща версия прошивки 1.0.0.2.
    Известные проблемы:
    <none>
    Changes:
    1) Fix configs scripts for support bash >=4 and change product name
    2) Kernel version up to 2.6.21.7
    3) Redesign filesystem. Busybox up to 1.15.3
    4) PPPD up to 2.4.5 with more patches as acell-ptpp/l2tp/gigaworld/allow-mppe/etc
    5) Add ACELL-PPTP Kernel support
    6) Mount ramfs particions in kernel mode
    7) BGIDGE: Pause frames shouldn't be passed up by driver anyway
    8) Add ESFQ support
    9) Initial auto detect memory size (fix me 32bit mode support)
    10) Add udpxy
    11) Code cleanup
    12) Remove ASUS Code
    13) Original Ralink gui now work
    14) pptp/l2tp/pppoe tun now works
    15) Full rc scrips is write in rwfs
    16) RT3052F embed switch full work now
    17) Rewrite pptp/l2tp/pppoe scripts to support buggy nas (corbina etc)
    18) miniupnpd now work too
    19) Add rwfs support (fs save | fs restore | fs load)
    20) Auto set mss size
    21) Masqrade now work correctly
    22) IMQ support added
    23) Initial shaper scripts (default priomap and esfq for decrase torrents prio)
    24) Kernel ip account support added
    25) Fix crash on sta list
    26) Update userspace daemons and utility
    27) Some busybox fixes
    28) Auto generate UUID for UPNP service on first upnpd start
    29) Check if ppp is up do not change ip from dhcp
    30) Regenerate mac if drop to defaults
    31) Some services start only then start goahead
    32) Replace some code from original Ralink SDK version 3.3
    33) Integrate new web gui in current sources tree
    34) Static routes get from dhcp server (options 79)
    35) busybox update to 1.16.0 version
    36) Replace ntpclient to ntpd from new busybox
    37) Add multiple default gateway support for load balacing
    38) Fix boot on 4/16 devices
    39) RootFS on flash work OK
    40) Fix resolve server ip for pptp/l2tp
    41) Add support others type falsh
    42) Job control fix
    For support see:
    acorp.ru - Acorp Electronics Inc.
    ddixlab.ru - Laboratory of built in systems.
    News and changes in Russian:
    sadnet.ru - Development opensource routers firmware
    Bug report please send sfstudio[_at_]mail.ru
    Желающие добавить поддержку других девайсов welcome с патчами.
    Все обсуждения касательно прошивки ведуться тут http://forum.nag.ru/forum/index.php?showtopic=54015
    Прежде чем писать советую прочитать тему целиом.
    кина не будет
    Сообщение от sfstudio Посмотреть сообщение
    из datasheet на rt3050/52 f (http://www.tracermcc.ru/foto/bender/...81408_0902.pdf , http://caxapa.ru/thumbs/271633/RT305...81408_0902.pdf , http://www.mediatek.com/_en/01_produ...ro.php?sn=1004 , http://www.mediatek.com/_en/01_produ...ro.php?sn=1003) :
    RT3050 - 1T1R _ 320 MHz
    Cache
    16K I-Cache + 16K D-Cache
    SDRAM
    16 bit (32MB)
    USB2.0 OTG x 1
    RT3052 - 2T2R _ 320/384 MHz
    Cache
    32K I-Cache + 16K D-Cache
    SDRAM
    16/32 bit (64MB)
    USB2.0 OTG x 1
