Прошил DIR 300 , и случайно поставил Local IP address: 9600
Как исправить? роутеру 2 дня, и денег на новый не имею
ПОМОГИТЕЕЕ!!!
Заранее огромное спасибо за ответы.
DD-WRT> ^C
DD-WRT> ip_address -h 192.168.1.2
IP: 192.168.1.1/255.255.255.0, Gateway: 0.0.0.0
Default server: 192.168.1.2
DD-WRT> fis init
About to initialize [format] FLASH image system - continue (y/n)? y
*** Initialize FLASH Image System
... Erase from 0xbffe0000-0xbfff0000: .
... Program from 0x80ff0000-0x81000000 at 0xbffe0000: .
DD-WRT> load -r -b 0x80041000 linux.bin
Using default protocol (TFTP)
TFTP timed out 1/15
Can't load 'linux.bin': operation timed out
TFTP timed out 1/15
TFTP timed out 1/15
TFTP timed out 1/15
Raw file loaded 0x80041000-0x803ddfff, assumed entry at 0x80041000
DD-WRT> fis create linux
... Erase from 0xbfc30000-0xbffcd000: .................................................. ........
... Program from 0x80041000-0x803de000 at 0xbfc30000: .................................................. ........
DD-WRT> fconfig boot_script true
boot_script: Setting to true
Update RedBoot non-volatile configuration - continue (y/n)? y
DD-WRT> fconfig boot_script_timeout 3
boot_script_timeout: Setting to 3
DD-WRT> fconfig bootp false
bootp: Setting to false
DD-WRT> fconfig
Run script at boot: true
Boot script:
Enter script, terminate with empty line
>> fconfig
>> fis load -l linux
>> exec
Boot script timeout (1000ms resolution): 3
Use BOOTP for network configuration: false
Gateway IP address:
Local IP address mask:
Default server IP address:
Console baud rate: 9600
GDB connection port: 9000
Force console for special debug messages: false
Network debug at boot time: false
DD-WRT> reset
ПОМОГИТЕЕЕ!!!
DD-WRT> ^C
DD-WRT> fis init
TFTP timed out 1/15
TFTP timed out 1/15
TFTP timed out 1/15
TFTP timed out 1/15
DD-WRT> fconfig
Boot script:
>> fconfig
>> fis load -l linux
>> exec
Gateway IP address:
DD-WRT> reset
