Да конечно. А ещё wifi излучение лишает девственности. =)))
Блялинк со своим софтом идёт лесом.
1.7.x 1) Add initial RT3662/RT3883 + RT309x support. 2) Wi-Fi coexistence now disable per default. (variable HT_BSSCoexistence 0/1 3) Add HT_BSSCoexApCntThr variable to install manually a switch-off threshold 40MHz mode wifi. If AP on air > HT_BSSCoexApCntThr. 4) Some init scrips more correct use some variable. 5) Do not send multicast and broadcast to PPE. Workaround for work IpTv in some configuration. Use CONFIG_RA_HW_NAT_SAFE for build. 6) Only packet has valid ethernet adress need send to PPE. Need for correct track uncknown sessions. Use CONFIG_RA_HW_NAT_SAFE for build. 7) Smal fix in memory size autodetect. 8) Fix xfrm build. 9) Backport some fixes from vanilla kernel. 10) Add config target for USB 2T2R devices at 8Mb Flash.
