Новая прошивка от Dlink 2100. Кто пробовал ? http://ftp.dlink.ru/pub/Wireless/DWL...Firmware/2.50/ Радует наличие IGMP Snooping..
DWL-2100AP Firmware Release Notes
Firmware: v2.50
Hardware: A4
Date: 08/10/28
Problems Resolved:
1. [FW] AP can't send standard traps.
2. [FW] rogue ap list should not be shown if band is not selected.
3. [APM] rogue ap list shows wrong.
4. [WEB] It can't reset data rate settings
5. [FW] The trap status and server ip can not be set.
6. [FW] When AP mode is wds with ap, there is a lack of some logs on Syslog.
7. [FW] use the wizard to configure the AP ,and set the password empty, then restart AP. the username will be changed from admin to empty
8. [FW] Something wrong with the help document
9. [FW] There is no image but update success by tftp.
10. [FW] Intel WiFi Link 4965AGN can’t connect to AP if authentication is WPA/WPA2 PSK, and vlan state is enabled.
Enhancements:
1. [FW] Modify GUI "11g only disable/enable" to "Wireless B/G Mode Mixed/11b only/11g only" default value will be "Mixed", support CLI command.
2. [FW] Support primary SSID with VLAN tag function.
3. [FW] Support administration VLAN(Manage VLAN) , administrate AP with WLAN and management IP range function.
4. [FW] Support WMM over WDS function.
5. [FW] Support IGMP Snooping (v1/v2) function.
6. [FW] Data Rate Control follows Dlink new spec.
7. [FW] Support IAPP (fast roaming)
8. [FW] Support Secondary RADIUS server setting
9. [FW] Enable/Disable ping to AP
10. [FW] Support Acct-Interim-Interval attribute for Accounting function,
11. [FW] Trap server, settings(categorize the types of traps)
12. AP status on UI
a) CPU and Memory utilization
b) Statistics for Ethernet TX and RX,bytes and packets
13. [CLI] CLI command to input SNMP Location.
14. [CLI] Hide the commands, get targetPower/gett controlPower/get swPower ,in CLI
15. [CLI]Open 3 RSTP commands, rstp getstp/rstp getstate/rstp setstate
---------------------- END ----------------------
Firmware: v2.50
Hardware: A4
Date: 08/10/28
Problems Resolved:
Enhancements:
12. AP status on UI
