...draw a...
Cardioid
The cardioid is a mathematical curve formed by the envelope of circles with centers on a given circle,
and passing through a fixed point on the given circle.
If so, follow the instructions below, to construct a mathematical curve,
1) Construct a circle with center A and passing through a point P.
2) Draw a free point on the circle and label it P:
3) Divide the circle into some number of equal arcs. In this example, there are 18.
4) Select Q, then P, and construct a circle with center Q and passing through P.
5)construct a circle with center R and passing through P.
6) Continue this process until you've completed the cardioid.
PS:R=12.335mm
OK!!??
Cardioid
PS:R=12.335mm
OK!!??
