Прошу помощи у форумчан. Есть 2 трупа NanoStation2, на сброс не реагируют, то есть не появляются ни по одному из адресов. При подключении консоли идёт загрузка и зависает. Может кто поможет.Заранее благодарен за помощ:)
Восстановление NanoStation2
Ъ+Ethernet eth0: MAC address 00:15:00:00:00:00
IP: 0.0.0.0/255.255.255.0, Gateway: 0.0.0.0
Default server: 0.0.0.0
RedBoot(tm) bootstrap and debug environment [ROMRAM]
Ubiquiti Networks certified release, version 0.9.8.06 - built 10:58:08, Dec 23 2008
Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
Board: Ubiquiti NanoStation2
RAM: 0x80000000-0x81000000, [0x80040880-0x80fe1000] available
FLASH: 0xbfc00000 - 0xbfff0000, 64 blocks of 0x00010000 bytes each.
== Executing boot script in 1.000 seconds - enter ^C to abort
RedBoot> cache off
RedBoot> fis load -d -e kernel
Trying LZMA decompression...
lzma_decode failed. res=2
Trying ZLIB decompression...
Image loaded from 0x80041000-0x8022f085
Image is not ELF, skipping ELF parsing...
RedBoot> go
@B@BB@B@@@@@@@@юб@BBBB@B─
на мак не смотрите изменил, вот такое и всё:(
Шнурок длинный. Должно помочь:
Putting the redboot into recovery mode:
Now that your terminal client is setup properly its time to power your NanoStation2 on again. You will start to see some scrolling text.
When you see the scrolling text press “CTRL+C” As quickly as you can. Don't worry about pressing it to much, you wont hurt anything here.
Note**(You may have to leave the nanostation AND usb 232 adapter disconnected from power and your computer for a few minutes before this will work.. Or at least that was my experience). Don t give up easily. Unless the hardware is completely toast you will get something with this.
If all is well you will be greeted with a screen that says something like the following:
RedBoot>
At this prompt we can put the NanoStation into Recovery mode.
Type the following:
RedBoot> urecovery
You should start seeing some text scrolling by asking about a TFTPD. This is how we are going to upload our .bin (firmware) to the device. I highly HIGLY suggest using the stock Ubiquity firmware at this point.
Сообщение от jass66 Посмотреть сообщениеТолько вместо команды urecovery команду urescue.
Сообщение от верховцев Посмотреть сообщениеогромное спасибо! получилось!
