TP-Link WA5210G - Команды консоли
    Подключился к консоли упомянутого девайса. Он пишет (если выкинуть пустые строки, с ними листинг гораздо длиннее):
    AR2315 rev 0x00000086 startup...
    Attached TCP/IP interface to ae unit 0
    Attaching interface lo0...done
    USRCONF : g_size = 21388
    Name = MODULE_USR_CONF_T , size = 12
    Name = UC_IEEE802_1X_CFG_DATA_T , size = 512
    Name = UC_ADVANCED_CFG_T , size = 16
    Name = UC_ARP_CFG_T , size = 652
    Name = UC_BPA_CFG_DATA_T , size = 912
    Name = UC_DDNS_T , size = 1480
    Name = UC_DHCPC_CFG_DATA_T , size = 416
    Name = UC_DHCPS_CFG_AND_STATIC_T , size = 708
    Name = UC_FIRE_WALL_STATE_T , size = 1992
    Name = UC_FORWARD_VIRTUAL_SERVE_CLASS_T , size = 1572
    Name = UC_LAN_CFG_DATA_T , size = 16
    Name = UC_L2TP_CFG_DATA_T , size = 1472
    Name = UC_MAC_CONFIG_T , size = 80
    Name = UC_PPPOE_CFG_DATA_T , size = 1664
    Name = UC_NTP_PREFER_SRV_CFG_DATA_T , size = 28
    Name = UC_STATIC_IP_CFG_DATA_T , size = 144
    Name = UC_SATTIC_ROUTE_CFG_DATA_T , size = 328
    Name = UC_MANAGE_USERS_T , size = 64
    Name = UC_UTILITIES_T , size = 16
    Name = UC_WANCONNTYPE_T , size = 16
    Name = UC_WLAN_CFG_T , size = 5196
    Name = UC_PWD_CFG_T , size = 20
    Name = UC_OPMODE_CFG_T , size = 4
    Name = UC_PPTP_CFG_DATA_T , size = 1472
    Name = UC_NETWORK_PSEUDO_T , size = 4
    Name = UC_QOS_ROUTER_CONF_FLASH_T , size = 740
    Name = UC_DHCPP_CFG_DATA_T , size = 1008
    Name = UC_SNMP_CFG_DATA_T , size = 844
    dsInit 1
    wlanBridgeInit(): ucGetOpMode() 3
    wireless access point starting...
    Auto Channel Scan selected 2472 MHz, channel 13
    wlan0 Ready
    beg
    Software Platform for ARM
    Copyright(C) 2001-2004 by TP-LINK TECHNOLOGIES CO., LTD.
    Creation date: Sep 30 2010, 09:57:06
    Press CTRL-B to enter bootmenu.end of init snmp
    TDDP: Now listening client request.
    tddp is running...
    Boot Menu:
    1: Download application program
    2: Modify Bootrom password
    3: Exit the menu
    4: Reboot
    5: User commond line
    Enter your choice(1-4):
    Из вышезаявленных опций действует только?! 5-я. Что бы это значило?
    У устройства есть опция для удалённой загрузки по сети навроде того, как это сделано в 2100?
    Последний раз редактировалось Sir; 13.10.2011, 12:39.
    За 4 дня около сотни просмотров и ни одного ответа....
    Неужели никто никогда не подключался к консоли 5210?!
    Или вся модернизация сабжа заключается в перепайке микросхемки с флешем?
      На какой порт и IP, я пытаюсь подключиться telnet но безуспешно.
        ет не на ип и порт. надо подключитса к последовательному порту на плате ТД - RS232 (в народе COM). Нужен также конвертер уровней COM <-> RS232 (подойдет MAX232). кстати, проверте напрежения, там мож бить 3.3в.
        Вобщем тема интересная. На днях попробую, эсть один 5210 для переделки в нанос. Перед реинкарнацией поекперементирую.
