Ребят, помогите, при прошивке дернули питание, теперь при включении точка мигает лампой Power, при подключении к Hyper Terminal дает следующее.....
ASSED
WAP-G02A Boot Procedure V1.0
Start ..Boot.B14..
Atheros AR5001AP default version 3.0.0.43A
0
auto-booting...
Attaching to TFFS... done.
Loading /fl/APIMG1...
Please wait, loading image ...
check runtime image signature error
image check fail!!!
error loading file: status = 0x3d0001.
Error loading RUNTIME file: errno = 0xd0003.
Loading /fl/backup...
image check ok!!!
/fl/ - Volume is OK
Reading Configuration File "/fl/apcfg".
apcfg: cannot set DHCPServer to 000000000000000000000000000000000000000000000000
00000000000000000000000000000000000000000000000000 000000000000000000000000000000
ТУТ МНОГО НУЛЕЙ !!!!!!!
00000000
apcfg: unknown config item IP_FILTER
apcfg: unknown config item matstate
apcfg: unknown config item trapState
apcfg: unknown config item sysTrap
apcfg: unknown config item wirelessTrap
apcfg: unknown config item memPoorPeriod
apcfg: unknown config item bcFloodPeriod
apcfg: unknown config item deAuthPeriod
apcfg: unknown config item deAuthCount
apcfg: unknown config item deAssocPeriod
apcfg: unknown config item deAssocCount
apcfg: unknown config item cpuloadlimit
apcfg: unknown config item cpuloadperiod
apcfg: unknown config item sysLogIP
apcfg: unknown config item sysLogRemote
apcfg: unknown config item sysLogLocal
apcfg: unknown config item sysLogSYS
apcfg: unknown config item sysLogWireless
apcfg: unknown config item sysLogOther
apcfg: unknown config item bridgeLearning
apcfg: unknown config item pktLogEnable
apcfg: unknown config item ofdmTrigLow
apcfg: unknown config item ofdmTrigHigh
apcfg: unknown config item cckTrigLow
apcfg: unknown config item cckTrigHigh
apcfg: unknown config item enableANI
apcfg: unknown config item noiseImmunityLvl
apcfg: unknown config item spurImmunityLvl
apcfg: unknown config item ofdmWeakSigDet
apcfg: unknown config item cckWeakSigThr
apcfg: unknown config item firStepLvl
apcfg: unknown config item ServiceType
apcfg: unknown config item RadarChRecordFlag
apcfg: unknown config item DiapEnable
apcfg: unknown config item wmmParam
apcfg: unknown config item wmmParamBss
apcfg: unknown config item TimeZoneOffSet
apcfg: unknown config item dayLightSaving
apcfg: unknown config item WDS
apcfg: unknown config item WMM
apcfg: unknown config item VLAN
apcfg: unknown config item SNMP_SrvIP
apcfg: unknown config item XR
apcfg: unknown config item XRPoll
apcfg: unknown config item XRQueueFrameLimit
apcfg: unknown config item XRQueuePollRate
apcfg: unknown config item XRFragmentThreshold
apcfg: unknown config item MinimumRate
apcfg: unknown config item vlanstate
apcfg: unknown config item nativevlan
apcfg: unknown config item RSTP
apcfg: unknown config item SSH
apcfg: unknown config item DLSAgent
apcfg: unknown config item dataratecontrol
apcfg: unknown config item basicdatarate
apcfg: unknown config item multi-ssidstate
apcfg: unknown config item Vlantag
apcfg: unknown config item MSSID_Config_v001
apcfg: unknown config item basisOfConnect
apcfg: unknown config item MRC_Enable
apcfg: unknown config item MaxMulticastRateIndex
apcfg: unknown config item MulticastPacketControl
apcfg: unknown config item MaxMulticastPacketNumber
apcfg: unknown config item jswProfile
Configuration file checksum: a71a87 is good
usrEndLibInit: wlan not found.
usrEndLibInit: enet not found.
apInit: no wlan device
AP initilization failed!
Attaching interface lo0...done
vxWorksTftpPackageInit: init. finish & success!
Ready
какие предпринять действия ???
ASSED
Start ..Boot.B14..
0
auto-booting...
image check fail!!!
image check ok!!!
/fl/ - Volume is OK
00000000
Ready
