Тада нечего тут писать бред всякий.
Модификация (аппаратная) TP-LINK TL-WA5210G в NanoStation2
приветствую, решил переделать 5110g в nanostation2, перепаял флеш на 25q32 и залил туда
NS2v401.bin
отсюда http://www.lan23.ru/forum/showthread...ll=1#post79426
NS2v40.bin
отсюдаhttp://www.lan23.ru/forum/showthread...ll=1#post78288
nanos2.bin
отсюда https://yadi.sk/d/5rC_5zeVDLsfa
я так понимаю флешка не подошла?
в терминале получил
PHP код:+Reading JEDEC MFID from flash failed. Trying RD_SIG.
Unknown flash (001640EF:0000), assuming 64 blocks of 65536 size
Unknown PHY: FFFF:FFFF
Ethernet eth0: MAC address 00:15:6d:df:3a:1c
IP: 192.168.1.20/255.255.255.0, Gateway: 0.0.0.0
Default server: 192.168.1.254
RedBoot(tm) bootstrap and debug environment [ROMRAM]
Ubiquiti Networks certified release, version 0.9.00483.1103151313 - built 13:14:44, Mar 15 2011
Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
Board: Ubiquiti Ubiquiti AR2315/6/7/8 based board (Ubiquiti NanoStation2 detected)
Arch: ar2316
RAM: 0x80000000-0x81000000, [0x80040b80-0x80fe1000] available
Flash: 0xbfc00000-0xbfff0000, in 64 blocks of 0x00010000 bytes each
== Executing boot script in 1.000 seconds - enter ^C to abort
RedBoot> cache off
RedBoot> fis load -d -e kernel
Trying LZMA decompression...
Image loaded from 0x80041000-0x801df25c
Entry point: 0x80196040, address range: 0x80042000-0x801bf000
RedBoot> go
[ 0.000000] CPU revision is: 00019064
[ 0.000000] Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
[ 0.000000] Primary data cache 16kB 4-way, linesize 16 bytes.
[ 0.000000] Linux version 2.4.27-ubnt0 (buildd@builder) (gcc version 3.3.3) #2 Tue Aug 23 17:28:37 EEST 2011
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 01000000 @ 00000000 (usable)
[ 0.000000] On node 0 totalpages: 4096
[ 0.000000] zone(0): 4096 pages.
[ 0.000000] zone(1): 0 pages.
[ 0.000000] zone(2): 0 pages.
[ 0.000000] Kernel command line: console=ttyS0,9600 console=ttyS0,9600 root=/dev/mtdblock2 rootfstype=squashfs init=/linuxrc ro
[ 0.000000] Using 92.000 MHz high precision timer.
[ 0.010000] Calibrating delay loop... 181.45 BogoMIPS
[ 0.290000] Memory: 14228k/16384k available (1351k kernel code, 2156k reserved, 88k data, 68k init, 0k highmem)
[ 0.410000] Dentry cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.490000] Inode cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.570000] Mount cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.650000] Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.730000] Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.810000] Checking for 'wait' instruction... unavailable.
[ 0.870000] POSIX conformance testing by UNIFIX
[ 0.930000] Linux NET4.0 for Linux 2.4
[ 0.970000] Based upon Swansea University Computer Society NET3.039
[ 1.050000] Initializing RT netlink socket
[ 1.100000] Starting kswapd
[ 1.130000] Squashfs 2.2-r2 (released 2005/09/08) (C) 2002-2005 Phillip Lougher
[ 1.220000] pty: 256 Unix98 ptys configured
[ 1.270000] Serial driver version 5.05c (2001-07-08) with no serial options enabled
[ 1.360000] ttyS00 at 0xb1100003 (irq = 37) is a 16550A
[ 1.430000] PPP generic driver version 2.4.2
[ 1.480000] PPP Deflate Compression module registered
[ 1.540000] MPPE/MPPC encryption/compression module registered
[ 1.610000] spiflash: JEDEC compatible device detected (Manufacturer: 0xEF; device: 0x4016)
[ 1.710000] spiflash: JEDEC device (Manufacturer: 0xEF; device: 0x4016) not recognized, trying STM signature...
[ 1.830000] mtd: adjusted dev mtd2 size from 61440 to 65536 bytes
[ 1.910000] Creating 8 MTD partitions on "spiflash":
[ 1.970000] 0x00000000-0x00030000 : "RedBoot"
[ 2.020000] 0x00030000-0x00100000 : "kernel"
[ 2.070000] 0x00100000-0x003c0000 : "cramfs"
[ 2.120000] 0x003c0000-0x003e0000 : "cfg"
[ 2.170000] 0x003e0000-0x003f0000 : "FIS directory"
[ 2.230000] 0x003ef000-0x003f0000 : "RedBoot config"
[ 2.290000] mtd: partition "RedBoot config" doesn't start on an erase block boundary -- force read-only
[ 2.400000] 0x003f0000-0x00400000 : "EEPROM"
[ 2.450000] 0x00030000-0x003e0000 : "Working flash"
[ 2.510000] Initializing Cryptographic API
[ 2.560000] NET4: Linux TCP/IP 1.0 for NET4.0
[ 2.610000] IP: routing cache hash table of 512 buckets, 4Kbytes
[ 2.680000] TCP: Hash tables configured (established 1024 bind 2048)
[ 2.760000] IPv4 over IPv4 tunneling driver
[ 2.810000] GRE over IPv4 tunneling driver
[ 2.860000] Linux IP multicast router 0.06 plus PIM-SM
[ 2.920000] NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
[ 2.990000] Ebtables v2.0 registered
[ 3.030000] NET4: Ethernet Bridge 008 for NET4.0
[ 3.090000] Bridge firewalling registered
[ 3.140000] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
[ 3.220000] All bugs added by David S. Miller <davem@redhat.com>
[ 3.300000] VFS: Mounted root (squashfs filesystem) readonly.
[ 3.370000] Freeing unused kernel memory: 68k freed
[ 3.440000] Warning: unable to open an initial console.
[ 3.910000] Algorithmics/MIPS FPU Emulator v1.5
UBNT login:
Последний раз редактировалось karp; 15.01.2015, 02:01.
Сообщение от karp Посмотреть сообщениеприветствую, решил переделать 5110g в nanostation2, перепаял флеш на 25q32 и залил туда
я так понимаю флешка не подошла?Программа для прошивки 5210G в NanoStation 2 - http://wa5210g.blogspot.com
Привет!!!!! Подскажите что может быть с 5210g я прошит точку в NanoStation2 через программатор впаял начил входить на точку зашел изменил параметры и нажал сохранить и преминить и после этого не могу не войти и не пингует!!!! Пробывал прошивать менял флешку и даже микросхему lan не чего не помогло что делать, а забыл светодиод горит lan и больше не чего!!!
Дамп FullFlash TP-LINK TL-WA5210G перешитого в NanoStation2
Firmware Version: XS2.ar2316.v4.0.2.WA5210G.SDK.130121.2203
MAC менять здесь:
WAN MAC: 00:15:6D:A5:94:44 Адрес Hex:3F0060
LAN MAC: 00:15:6D:AC:94:4A Адрес Hex:3F0066
После пары недель использования остался крайне недоволен работой NanoStation2. Связь была заметно менее стабильной, вернул обратно прошивку TL-WA5210GПоследний раз редактировалось Sana956; 23.12.2015, 12:19.
