Из консоли микротика пингую ком glserver (192.168.3.100) по ip пинг есть по имени нет ... как быть? и компы по VPN по имени не ходят((
Mikrotik и netbios
# jan/05/1970 15:50:38 by RouterOS 5.11
# software id = LBWA-X3KT
/interface ethernet
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=D4:CA:6D:38:08:88 mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:38:08:89 \
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:38:08:8A \
master-port=ether2 mtu=1500 name=ether3-slave-local speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:38:08:8B \
master-port=ether2 mtu=1500 name=ether4-slave-local speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:38:08:8C \
master-port=ether2 mtu=1500 name=ether5-slave-local speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \
name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=\
1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m \
name=default pfs-group=modp1024
/ip pool
add name=dhcp_pool2 ranges=192.168.0.2-192.168.0.254
/ip dhcp-server
add address-pool=dhcp_pool2 authoritative=after-2sec-delay bootp-support=\
static disabled=no interface=ether2 lease-time=3d name=dhcp1
/ppp profile
set default change-tcp-mss=yes idle-timeout=23h name=default only-one=default \
session-timeout=23h use-compression=no use-encryption=no use-mpls=default \
use-vj-compression=no
set default-encryption change-tcp-mss=yes name=default-encryption only-one=\
default use-compression=default use-encryption=yes use-mpls=default \
use-vj-compression=default
/interface l2tp-client
add add-default-route=no allow=pap,chap,mschap1,mschap2 connect-to=\
******** dial-on-demand=yes disabled=no max-mru=1460 max-mtu=1460 \
mrru=disabled name=l2tp-ykdav password=******** profile=\
default-encryption user=*****
/interface pptp-client
add add-default-route=yes allow=pap,chap,mschap1,mschap2 connect-to=\
10.10.10.1 dial-on-demand=yes disabled=no max-mru=1400 max-mtu=1400 mrru=\
disabled name=pptpyota password=********** profile=default user=\
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 \
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=\
5
set only-hardware-queue kind=none name=only-hardware-queue
set multi-queue-ethernet-default kind=mq-pfifo mq-pfifo-limit=50 name=\
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in \
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=\
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=\
default
/snmp
set contact="" enabled=no engine-id="" location="" trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=\
DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=5 disk-file-name=log disk-lines-per-file=1000 \
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=\
400MHz force-backup-booter=no silent-boot=no
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,p assword,w\
eb,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,wi nbox,pa\
ssword,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,pol icy,test,\
winbox,password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
no
/interface ethernet switch port
set ether2 vlan-header=leave-as-is vlan-mode=fallback
set ether3-slave-local vlan-header=leave-as-is vlan-mode=fallback
set ether4-slave-local vlan-header=leave-as-is vlan-mode=fallback
set ether5-slave-local vlan-header=leave-as-is vlan-mode=fallback
set switch1_cpu vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:A5:57:72:9D:EC \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ip address
add address=192.168.0.1/24 comment="default configuration" disabled=no \
interface=ether2 network=192.168.0.0
add address=10.10.3.253/24 disabled=no interface=ether1 network=10.10.3.0
/ip dhcp-client
add comment="default configuration" default-route-distance=1 disabled=no \
interface=ether1
/ip dhcp-server config
set store-leases-disk=5m
/ip dhcp-server network
add address=192.168.0.0/24 gateway=192.168.0.1
/ip dns
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=512 servers=192.168.137.1,4.2.2.4
/ip firewall connection tracking
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall filter
add action=accept chain=input comment="Added by webbox" disabled=no protocol=\
icmp
add action=accept chain=input comment="dostup k mikrotik" disabled=no
add action=accept chain=input comment="Added by webbox" connection-state=\
established disabled=no in-interface=pptpyota
related disabled=no in-interface=pptpyota
add action=drop chain=input comment="Added by webbox" disabled=no \
add action=jump chain=forward comment="Added by webbox" disabled=no \
in-interface=pptpyota jump-target=customer
add action=accept chain=customer comment="Added by webbox" connection-state=\
related disabled=no
add action=drop chain=customer comment="Added by webbox" disabled=no
/ip firewall nat
add action=masquerade chain=srcnat comment="Added by webbox" disabled=no \
src-address=192.168.0.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 disabled=yes
set ether2 disabled=no
set ether3-slave-local disabled=no
set ether4-slave-local disabled=no
set ether5-slave-local disabled=no
set pptpyota disabled=yes
set l2tp-ykdav disabled=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
0.0.0.0
/ip route
add disabled=no distance=1 dst-address=10.10.0.0/16 gateway=10.10.3.254 \
scope=30 target-scope=10
add check-gateway=ping disabled=yes distance=1 dst-address=10.10.3.0/24 \
gateway=10.10.3.255 scope=30 target-scope=10
add disabled=no distance=1 dst-address=192.168.0.0/24 gateway=192.168.222.2 \
add disabled=no distance=1 dst-address=192.168.3.0/24 gateway=192.168.222.1 \
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=80
set ssh disabled=no port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=no enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=ether1 type=internal
add disabled=no interface=ether2 type=internal
add disabled=no interface=ether3-slave-local type=internal
add disabled=no interface=ether4-slave-local type=internal
add disabled=no interface=ether5-slave-local type=internal
add disabled=no interface=pptpyota type=external
add disabled=no interface=l2tp-ykdav type=internal
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/ppp secret
add caller-id="" comment="Some description" disabled=no limit-bytes-in=0 \
limit-bytes-out=0 local-address=192.168.10.1 name=**** password=****** \
profile=default remote-address=192.168.10.2 routes="" service=l2tp
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3-slave-local queue=only-hardware-queue
set ether4-slave-local queue=only-hardware-queue
set ether5-slave-local queue=only-hardware-queue
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=Europe/Moscow
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system health
set
/system identity
set name=MikroTik
/system logging
add action=disk disabled=no prefix="" topics=info
add action=disk disabled=no prefix="" topics=error
add action=disk disabled=no prefix="" topics=warning
add action=disk disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=94.242.49.220 secondary-ntp=\
95.140.150.140
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
/system scheduler
add disabled=no interval=5m name=ScSetL2TP on-event=\
"/system script run SetL2TP" policy=\
ftp,reboot,read,write,policy,test,winbox,password, sniff,sensitive,api \
start-date=jan/01/1970 start-time=01:51:34
/system script
add name=EnaSched_1 policy=reboot,read,write,policy,test,password,snif f \
source=\
":log info \"VPN upal zapuskaem zanovo\"\r\
\n/system script run SetL2TP"
add name=DisaSched_1 policy=\
ftp,reboot,read,write,policy,test,winbox,password, sniff,sensitive source=\
"sys sched disa SetL2TP"
add name=script1 policy=\
source=":global newr1 [:resolve *********]\r\
\n/int l2tp-client set l2tp-ykdav connect-to=\$newr1\r\
\n:log info \"SetL2TPscript:Changing IP ****************\r\
\n"
add name=SetL2TP policy=\
source=":global newr1 [:resolve **************]\r\
\n:log info \"SetL2TPscript:Changing IP **************\"\r\
\n"
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
/tool mac-server
set (unknown) disabled=no interface=ether2
set (unknown) disabled=no interface=ether3-slave-local
set (unknown) disabled=no interface=ether4-slave-local
set (unknown) disabled=no interface=ether5-slave-local
/tool mac-server ping
set enabled=yes
/tool netwatch
add disabled=no down-script=EnaSched_1 host=192.168.3.100 interval=15s \
timeout=1s up-script=DisaSched_1
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-stream=yes interface=all \
memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=\
no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
Сообщение от Algon Посмотреть сообщениеА сервер куда подключается?
Тик как настроен?
З.Ы. Как вы считаете, что из вас информацию надо клещами тянуть - это нормально?
[admin@MikroTik] > ping 192.168.3.100
HOST SIZE TTL TIME STATUS
192.168.3.100 56 127 7ms
sent=1 received=1 packet-loss=0% min-rtt=7ms avg-rtt=7ms max-rtt=7ms
[admin@MikroTik] > ping glserver
while resolving ip-address: name does not exis
Ясно. Я у вас просил не экспорт настроек, а краткое описание.
Если у вас компы и сервер подключены через свич, и не пингуются, то при чем здесь Микротик?
Вообще-то по именам нетбиос они и не должны пинговаться. Пинг это команда протокола TCP/IP, и если вы хотите адресацию в сети не по IP, а по именам, то нужно поднимать DNS-сервер. Если он уже поднят на МТ и является основным для вашей сети, то нужно там задать статические сопоставления адресов и IP (именно в DNS).
Сообщение от Algon Посмотреть сообщениеНу вот с этого и нужно было начинать. Значит вам нужен netbios через VPN? Обычно это проблема решается на уровне ARP. Проверьте что разрешено на всех интерфейсах. Если везде разрешено, но не работает - попробуйте переключить LAN в режим ARP-proxy.
во всех LAN стоит ARP - enable, на LAN2 - которому подключен свитч ARP-proxy
Сообщение от wolf_ktl Посмотреть сообщениеМожет дело в том, что мне надо поднять EoIP по верх L2TP ?
З.Ы. Обычно задача как раз состоит в том, чтобы зарезать на МТ постоянно флудящий нетбиос...
