Вот сделал как вы сказали посмотрите...
U-Boot 1.1.4.2-s564 (Jul 19 2012 - 10:41:56)
Board: Ubiquiti Networks XM board (rev 1.0 e8a5)
DRAM: 16 MB
Flash: 8 MB
PCIe WLAN Module found (#1).
Net: eth0, eth1
Hit any key to stop autoboot: 0
ar7240> setenv bootargs console=ttyS0
Unknown command 'setenv' - try 'help'
ar7240> setenv bootargs console=ttyS0,115200 root=31:03 rootfstype=squashfs init =/init
ar7240>
ar7240> setenv
Usage:
setenv - set environment variables
ar7240> saveenv
Saving Environment to Flash...
Un-Protected 1 sectors
Erasing Flash.... done
Erased 1 sectors
Writing to Flash... done
Protected 1 sectors
ar7240> reset
Resetting...
DRAM: 16 MB
Flash: 8 MB
Net: eth0, eth1
## Booting image at 9f050000 ...
Image Name: MIPS Ubiquiti Linux-2.6.32.54
Created: 2014-02-05 16:25:36 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1047649 Bytes = 1023.1 kB
Load Address: 80002000
Entry Point: 80002000
Verifying Checksum ... OK
Starting kernel ...
Booting...
[ 0.000000] Linux version 2.6.32.54 (buildd@builder) (gcc version 4.1.2) #1 W ed Feb 5 18:25:32 EET 2014
[ 0.000000] flash_size passed from bootloader = 0
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 01000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00001000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00001000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pa ges: 4064
[ 0.000000] Kernel command line: console=ttyS0,115200 root=31:03 rootfstype=s quashfs init=/init mtdparts=ar7240-nor0:256k(u-boot),64k(u-boot-env),1024k(kerne l),6528k(rootfs),256k(cfg),64k(EEPROM)
[ 0.000000] PID hash table entries: 64 (order: -4, 256 bytes)
[ 0.000000] Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 13144k/16384k available (2290k kernel code, 3240k reserve d, 539k data, 136k init, 0k highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:128
[ 0.000000] plat_time_init: plat time init done
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] Calibrating delay loop... 259.58 BogoMIPS (lpj=129792)
[ 0.016000] Mount-cache hash table entries: 512
[ 0.019000] NET: Registered protocol family 16
[ 0.021000] ===== ar7240_platform_init: 0
[ 0.021000] PCIe WLAN H/W found [tries: 1]
[ 0.021000] PCI init:ar7240_pcibios_init
[ 0.021000] ar7240_pcibios_init(368): PCI CMD write: 0x356
[ 0.021000] registering PCI controller with io_map_base unset
[ 0.030000] bio: create slab <bio-0> at 0
[ 0.032000] usbcore: registered new interface driver usbfs
[ 0.032000] usbcore: registered new interface driver hub
[ 0.033000] usbcore: registered new device driver usb
[ 0.034000] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 0.034000] pci 0000:00:00.0: PME# disabled
[ 0.034000] Returning IRQ 48
[ 0.035000] Switching to clocksource MIPS
[ 0.038000] NET: Registered protocol family 2
[ 0.038000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.040000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.040000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.040000] TCP: Hash tables configured (established 512 bind 512)
[ 0.040000] TCP reno registered
[ 0.041000] NET: Registered protocol family 1
[ 0.041000] AR7240 GPIOC major 0
[ 0.043000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.043000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY ) (c) 2001-2006 Red Hat, Inc.
[ 0.044000] msgmni has been set to 25
[ 0.044000] io scheduler noop registered (default)
[ 0.070000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.071000] serial8250.0: ttyS0 at MMIO 0xb8020000 (irq = 19) is a 16550A
[ 0.372000] console [ttyS0] enabled
[ 0.377000] 6 cmdlinepart partitions found on MTD device ar7240-nor0
[ 0.384000] Creating 6 MTD partitions on "ar7240-nor0":
[ 0.389000] 0x000000000000-0x000000040000 : "u-boot"
[ 0.395000] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.402000] 0x000000050000-0x000000150000 : "kernel"
[ 0.408000] 0x000000150000-0x0000007b0000 : "rootfs"
[ 0.415000] mtd: partition "rootfs" set to be root filesystem
[ 0.421000] 0x0000007b0000-0x0000007f0000 : "cfg"
[ 0.427000] 0x0000007f0000-0x000000800000 : "EEPROM"
[ 0.433000] usbmon: debugfs is not available
[ 0.437000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.474000] Port Status c000004
[ 0.478000] ar7240-ehci ar7240-ehci.0: ATH EHCI
[ 0.482000] ar7240-ehci ar7240-ehci.0: new USB bus registered, assigned bus n umber 1
[ 0.491000] ehci_reset Intialize USB CONTROLLER in host mode: 3
[ 0.498000] ehci_reset Port Status c000000
[ 0.502000] ar7240-ehci ar7240-ehci.0: irq 3, io mem 0x1b000000
[ 0.509000] ehci_reset Intialize USB CONTROLLER in host mode: 3
[ 0.516000] ehci_reset Port Status c000000
[ 0.527000] ar7240-ehci ar7240-ehci.0: USB 2.0 started, EHCI 1.00
[ 0.533000] usb usb1: configuration #1 chosen from 1 choice
[ 0.539000] hub 1-0:1.0: USB hub found
[ 0.543000] hub 1-0:1.0: 1 port detected
[ 0.548000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.555000] u32 classifier
[ 0.558000] Performance counters on
[ 0.561000] input device check on
[ 0.565000] Actions configured
[ 0.571000] TCP westwood registered
[ 0.575000] NET: Registered protocol family 10
[ 0.583000] NET: Registered protocol family 17
[ 0.588000] Bridge firewalling registered
[ 0.592000] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
[ 0.599000] All bugs added by David S. Miller <davem@redhat.com>
[ 0.605000] ar7240wdt_init: Registering WDT success
[ 0.621000] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[ 0.629000] Freeing unused kernel memory: 136k freed
[ 0.648000] Please be patient, while AirOS loads ...
[ 0.679000] CPU 0 Unable to handle kernel paging request at virtual address c 0068de4, epc == 800f8010, ra == 800f7f98
[ 0.690000] Oops[#1]:
[ 0.690000] Cpu 0
[ 0.690000] $ 0 : 00000000 802f0000 c0068de4 fffc3fb4
[ 0.690000] $ 4 : 00020000 00003fb4 fffe0000 24e486dc
[ 0.690000] $ 8 : 00002000 ffffffbf 00080000 00000000
[ 0.690000] $12 : 802b43a8 57ff5fdd 80cd63a0 00000001
[ 0.690000] $16 : 00000000 00000002 00000010 c00a4644
[ 0.690000] $20 : ffffffff 00000003 00002d98 c00a4000
[ 0.690000] $24 : 00000001 80010804
[ 0.690000] $28 : 80c1a000 80c1b998 c006a000 800f7f98
[ 0.690000] Hi : 00000000
[ 0.690000] Lo : 27ef6380
[ 0.690000] epc : 800f8010 unlzma+0xc48/0xdd8
[ 0.690000] Not tainted
[ 0.690000] ra : 800f7f98 unlzma+0xbd0/0xdd8
[ 0.690000] Status: 1000ff03 KERNEL EXL IE
[ 0.690000] Cause : 00800008
[ 0.690000] BadVA : c0068de4
[ 0.690000] PrId : 00019374 (MIPS 24Kc)
[ 0.690000] Modules linked in:
[ 0.690000] Process swapper (pid: 1, threadinfo=80c1a000, task=80c18938, tls= 00000000)
[ 0.690000] Stack : 80de1f88 00000748 800a12f0 80c12d64 00000003 0000001b 000 0001c 5d000200
[ 0.690000] 00000000 000001f3 0023b950 800f721c c00491b5 c0048000 c00 4ff49 00007f49
[ 0.690000] 100700f1 16361190 16361190 00000002 00003fb4 00000007 000 00008 00000002
[ 0.690000] 000000a4 00000000 00000000 c0048000 00000000 00000003 000 00003 80c18938
[ 0.690000] 80300000 80cf0484 00000000 00000000 00000021 c004ff49 000 00021 80cf5d40
[ 0.690000] ...
[ 0.690000] Call Trace:
[ 0.690000] [<800f8010>] unlzma+0xc48/0xdd8
[ 0.690000] [<800cb208>] lzma_uncompress+0x128/0x270
[ 0.690000] [<800c7254>] squashfs_read_data+0x484/0x690
[ 0.690000] [<800c7938>] squashfs_cache_get+0x1cc/0x310
[ 0.690000] [<800c8c3c>] squashfs_readpage+0x5e0/0x8b4
[ 0.690000] [<8005fbec>] __do_page_cache_readahead+0x1c0/0x218
[ 0.690000] [<8005fc6c>] ra_submit+0x28/0x34
[ 0.690000] [<800601b8>] page_cache_sync_readahead+0x5c/0x68
[ 0.690000] [<80058b64>] generic_file_aio_read+0x2ac/0x760
[ 0.690000] [<8007dc34>] do_sync_read+0xd4/0x13c
[ 0.690000] [<800826ec>] kernel_read+0x2c/0x40
[ 0.690000] [<80082808>] prepare_binprm+0x108/0x120
[ 0.690000] [<80083b14>] do_execve+0x104/0x29c
[ 0.690000] [<800093a4>] sys_execve+0x4c/0x78
[ 0.690000] [<8000d1c4>] stack_done+0x20/0x3c
[ 0.690000]
[ 0.690000]
[ 0.690000] Code: 00661821 02c51023 03c21021 <90520000> 03d61821 26d60001 0803e020 a0720000 8fa50050
[ 0.690000] Disabling lock debugging due to kernel taint
[ 0.918000] Kernel panic - not syncing: Attempted to kill init!
DRAM: 16 MB
Flash: 8 MB
Net: eth0, eth1
ar7240>
ar7240> setenv
Usage:
ar7240> saveenv
Erased 1 sectors
Protected 1 sectors
ar7240> reset
Resetting...
DRAM: 16 MB
Flash: 8 MB
Net: eth0, eth1
Starting kernel ...
Booting...
[ 0.690000] Cpu 0
[ 0.690000] ...
[ 0.690000]
[ 0.690000]
